Smart Zigbee 3.0 Water Leak Detector Wireless Water Leakage Sensor for Home Overflow Monitoring Work with Home Assistant
Warm Tips
Please note that when you pair it with Home Assistant, the ZigBee hub is required for pairing.
The latest version is NOT compatible with Tuya ZigBee Gateway and Tuya APP.
In the event that any issues arise with the product following its receipt, please do not hesitate to contact our online after-sales team for assistance. Our specialists are available to provide prompt support and resolve any concerns in a professional manner.
ITEM DESCRIPTION
-Detect Water Leaking/Dripping Remotely
With this smart water leak detector, you can monitor your home's water overflow security in real-time using your smartphone. Help you keep an eye on potential water leaks when you are not at home.
-Instant Alerts
Receive real-time notifications when leaks are detected, especially in critical areas like the laundry room, washroom, or kitchen, ensuring prompt action to protect your home.
-IP66 Waterproof and Durable
Designed with IP66 waterproofing, providing reliable operation even in highly humid environments.
-Smart Automation Scenes
Integrate this smart water leakage sensor with other ZigBee 3.0 smart devices for seamless home automation. For instance, close the water valve in case of kitchen sink leaks or trigger window closure when water is detected on the windowsill.
-Tool-free Installation
You don't need any complicated wiring or tools. Just put it to the place where you want to monitor for water leaks.
Detect Water Leakage Remotely
Instant Alerts
Receive real-time notifications when leaks are detected, especially in critical areas like the laundry room, washroom, or kitchen, ensuring prompt action to safeguard your home.
Not Only Detect
But Also Protect
You don't need any complicated wiring or tools. Just put it in the place where you want to monitor for water leaks.
ZigBee 3.0 Gateway Hub Required
ZigBee 3.0 gateway is required when you pair this smart water leak sensor.
SPECIFICATION
Type:ZigBee Smart Water Leak Sensor
Model: Smart Water Immersion Detector
Standard: Wireless Water Leakage Monitor
Wireless Protocol: ZigBee
Battery Type:1*CR2032(Included)
Working Temperature: -10℃-55℃
Working Humidity: 0-100%
Hub Requirement: Yes
Packing List
1*Smart Water Leak Detector
1*Prybar
1*CR2032
