Smart ZigBee GU10 WiFi Smart LED Light Bulb RGB C+W 5W Dimmable Lamps EWelink APP Control Spotlight Bulb Works With Alexa Google
  • Warranty: 3years
  • Area: 3-8㎡
  • Is Smart Device: YES
  • Model Number: eWelink Zigbee WiFi smart GU10 bulb
  • Luminous Flux: 250 - 499 Lumens
  • Warranty: 3years
  • Area: 3-8㎡
  • Color Temperature: 2700K~6500K
  • Voltage: AC100-240V
  • Occasion: LIVING ROOM
  • Power Tolerance: 5%
  • LED Chip Brand: Epistar
  • Shape: IRREGULAR
  • Beam Angle(°): 120°
  • Length: 0.06m
  • Base Type: GU10
  • Origin: Mainland China
  • Item Type: LED bulbs
  • Brand Name: coolo
  • Led Bulb Type: Spotlight Bulb
  • Certification: ce,FCC,ROHS
  • Average Life (hrs): 30000
  • LED Chip Model: 2835
Type: Zigbee / WiFi Smart LED GU10 Bulb
Material: Aviation Aluminum, plastic
Socket Type: GU10
Power: 5W
Voltage: AC 100V~240V
Lumen: 350lm
Life: >30000h
APP Download: eWelink
Network: 2.4GHz Wi-Fi/Zigbee 3.0(need Zigbee Hub Gateway)
Light color: RGB + Warm white + White (3000K-6000K)
Function: Voice Control, APP Remote Control, Dimmable, Compatible with Amazon Alexa Echo Google Home Assistant.
Zigbee Hub As Control Central: Zigbee Gateway Hub is Required for Zigbee bulb, performing as the center bridge for all zigbee device with extremely stable signal and a really good necessity for whole-house intelligence.
Note: If you don't have zigbee hub gateway, just buy WiFi type.
