Smart Zigbee USB Led Lights RGB Led Strip DC5V 5050 Smart Led TV Backlight Tape Lighting Wok with Alexa Google Home Smartthings
$38.15
Emitting Color: 1M Kit
Color: Ip20 Not Waterproof
Caution:
(1)zigbee Led controller need work with zigbee gateway,like tuya zigbee,Smartthings, eWelink,Z2mqtt.
(2) 5V light need use USB 5V power.
Product parameter:
SMD5050 RGB light strip
(1) Working Voltage: DC 5V
(2) LED Source: SMD 5050 RGB LED
(3) LED QTY: 30LEDS/M
(4) PCB:Black No-waterproof
(5) Cutability: every LED is cuttable
(6) Beam Angle: 120 °
(7)Connector: 4pin:+,G,R,B
Zigbee RGB Controller:
(1)Product Name:zigbee mini Strip Controller
(2)Color: White
(3)Version:RGB(4PIN)
(4)Voltage: DC5V
(5)Output: Max. 0-3A/Channel
(6)Control App: smart life
(7)Control Signal: Wi-Fi 2.4GHz
(8)Support system: Alexa Home/ECHO
(9)Support mobile: Android/IOS
(10)Size:64*24*12(mm)
(11)Operating Temperature:-20-60°
Package include:
1xDC5V RGB light strip(the length is according your choose)
1xUSB RGB controller
