Smart Zigbee Water Sensor Flood Water Leakage Detector App Remote Monitoring Support Home Assistant Zigbee2Mqtt
Note:
Noted:It won't work with tuya zigbee hub.just work with home assitant zigbee2mqtt
When purchasing a product, please read the product title clearly. Zigbee products are standard Zigbee 3.0 protocol products that can be connected to home assistant Zigbee 2mqtt, Yadex, Alexa and other standard Zigbee 3.0 protocol gateways and speakers. It is not recommended for users to connect to the tuya Zigbee gateway for use.
Description:
[Use anywhere]-No cable, can be placed anywhere you want
【Real-time detection】 The water immersion sensor can detect water leakage in the environment in real time. When water immersion is detected, the detector will send an alarm signal to the host and report the information to the user's mobile phone. When the water level at the detection point reaches 0.01M, the water intrusion sensor will report the water condition.
[Scene Linkage] The preset security scene is realized through the mobile phone APP. Once the monitored water level reaches a preset height, an alarm is remotely sounded.
[Detection of new] using advanced detection module, real-time water induction. When water flows through the two poles of the probe, an alarm message is immediately sent to the Gateway.
[Long battery life, low battery reminder] low power consumption technology. Using high-performan
