SONOFF B02-B-A60/ B05-BL-A60 WiFi Smart LED Bulb E27 Dimmable RGB Lamp Bulbs 9W 220V-240V Smart Home eWeLink APP Control
Voice Control: Adjust brightness and color settings or turn the bulb on/off through Alexa or Google Assistant
Scene and Schedule Modes: Automate your lighting to switch on or off based on your daily routines
Energy-Efficient: With a lifespan of approximately 15,000 hours and minimal power consumption (only 9.9 kWh per year), this smart bulb helps lower electricity costs
Group Control: Manage multiple smart bulbs at once to maintain a consistent ambiance across your home
The SONOFF B02-B-A60/B05-BL-A60 WiFi Smart LED Bulb is a powerful, energy-efficient lighting solution designed to integrate seamlessly into modern smart homes. Offering advanced control through the eWeLink app, it provides adjustable brightness and color settings, making it perfect for various environments. Whether you prefer warm ambient lighting or vibrant RGB colors, this bulb adapts to your mood and tasks with ease. Voice control compatibility with Alexa and Google Home enhances its hands-free functionality, adding convenience to everyday routines.
The Wifi Smart LED bulb from SONOFF brings intelligent control to your home lighting. With its E27 base, it fits most standard fixtures, making installation straightforward. Supporting both Wifi Dimmable LED bulb functionality and group control through the eWeLink app, you can manage multiple lights simultaneously, adjusting brightness, temperature, and color settings with just a few taps.
This LED Light bulb operates at 9W, producing 806 lumens—comparable to a traditional 60W incandescent bulb—while significantly reducing energy consumption. With a wide color temperature range from 2700K to 6500K, the bulb lets you set the perfect atmosphere, from warm and cozy to bright and energetic lighting. If you need colorful lighting options, the B05-BL-A60 RGB model provides an extensive color palette to create immersive scenes.
- Voice Control: Adjust brightness and color settings or turn the bulb on/off through Alexa or Google Assistant.
- Scene and Schedule Modes: Automate your lighting to switch on or off based on your daily routines.
- Energy-Efficient: With a lifespan of approximately 15,000 hours and minimal power consumption (only 9.9 kWh per year), this smart bulb helps lower electricity costs.
- Group Control: Manage multiple smart bulbs at once to maintain a consistent ambiance across your home.
Designed for ultimate convenience, this Wifi Dimmable LED bulb also supports scene linkage, allowing it to respond to actions like opening doors when connected to additional sensors. Its versatility and smart automation features make it a perfect addition to any smart home setup, helping you optimize comfort and energy use throughout the day.
