Temperature Sensor Zigbee Smart Air Pressure Humidity Environment Sensor Wireless Smart Control for Xiaomi Mi Home APP
$42.60
Color: 1 Pc
Original Aqara Temperature Humidity Sensor Zigbee Smart Air Pressure Environment Sensor Smart Home For Xiaomi Mihome Homekit Homekit APP
Please read this before you buy
1. This sensor must match the xiaomi multifunctional gateway or Aqara gateway hub ( need to be purchased separately ) to use.
2. Aqara gateway hub is required to make this sensor to work with HomeKit.
Specifications
● Model: WSDCGQ11LM
● Battery: CR2032 (included)
● Wireless Protocol: Zigbee
● Dimensions: 36 × 36 × 9 mm (1.42 × 1.42 × 0.35 in.)
● Temperature Range and Precision: -20℃~+50°C, ±0.3℃ (-4℉~+122℉, ±0.5°F)
● Humidity Range and Precision: 0 – 100% RH (non-condensing), ±3%
● Atmospheric Pressure Range and Precision: 30 kPa – 110 kPa, ±0.12 kPa
● App: Apple Home app (iOS 10.3 or later), Aqara Home app (Android 5.0 or later, iOS 10.3 or later), Mi Home app
Highlights
● ZigBee wireless connection, no wiring required
● Monitors temperature, humidity, and atmospheric pressure in real time.
● REMOTE MONITORING: When the room temperature reaches above or below a certain threshold, the Aqara Temperature and Humidity Sensor can send a push alert to your phone or trigger other devices.
● HOME AUTOMATION: The Aqara Temperature and Humidity Sensor can control other connected devices such as Aqara Smart Plug to ensure that your fan or humidifier maintains a constant level of comfort for you and your family.
●ACCURATE MEASUREMENT: Utilizes high-quality sensor from the industry-leading manufacturer, Sensirion.
● BUILT-IN AIR PRESSURE SENSOR: Monitors the ambient air pressure in the room.
● Can work with Homekit, Mi Home
Packing List
Temperature and Humidity Sensor x 1
Sticker x 1
Quick Start Guide x 1
No Wiring Required | Temperature and Humidity Reminder | 2 Years Battery Life
* An Aqara hub is required.
The Aqara Temperature Sensor is a smart home device that measures temperature, air pressure, and humidity. It utilizes the Zigbee wireless protocol to communicate with other smart home devices. The sensor is designed to work with the Xiaomi Mi Home app and is also compatible with the Apple HomeKit ecosystem.
With the Aqara Temperature Sensor, you can monitor the temperature, air pressure, and humidity levels in your home. This information can be useful for managing indoor comfort, adjusting heating or cooling systems, and detecting potential issues like excessive humidity or low air pressure.
By connecting the Aqara Temperature Sensor to the Xiaomi Mi Home app or integrating it into your Apple HomeKit setup, you can receive real-time data readings and set up automation rules. For example, you can create scenes that trigger certain actions based on specific temperature or humidity thresholds. This allows for a more personalized and automated smart home experience.
