Tuya Smart Life Zigbee Smart Door Window Sensor Door Open Closed Detector Security Protection Alexa Google Home Voice Control
  • Real-Time Alerts: Receive instant notifications on your smartphone through the Tuya Smart Life app whenever a door or window is opened or closed, keeping you updated o..
Enhance your home security with the Tuya Smart Life Zigbee Smart Door and Window Sensor. This smart home door sensor is designed to detect the open or closed status of your doors and windows in real time, providing peace of mind whether you're at home or away. By integrating seamlessly with your existing smart home ecosystem, it ensures you're always informed about the security of your property.
  • Real-Time Alerts: Receive instant notifications on your smartphone through the Tuya Smart Life app whenever a door or window is opened or closed, keeping you updated on any unexpected activity.
  • Voice Assistant Compatibility: The sensor works effortlessly with Amazon Alexa and Google Assistant, allowing you to check the status of your doors and windows using simple voice commands.
  • Low Power Consumption: Equipped with a low-power design, the sensor offers extended battery life, reducing the frequency of battery replacements and ensuring continuous protection.
  • Easy Installation: With its compact and lightweight design, the sensor can be easily mounted on any door or window using the included double-sided tape or screws, making the setup process quick and hassle-free.
Install the Zigbee door sensor on any door, window, or even on items like refrigerators and safes to monitor their status. Once installed and connected to the Tuya Zigbee Hub, you can customize automation scenarios. For example, set the sensor to turn on lights automatically when a door is opened, enhancing both security and convenience.
  • Enhanced Security: By monitoring entry points in real time, the sensor helps deter unauthorized access and alerts you to potential security breaches.
  • Seamless Integration: As a Zigbee open/close detector, it integrates smoothly with other Zigbee devices, allowing for expanded automation possibilities within your smart home network.
  • Historical Data Tracking: The Tuya Smart Life app maintains a log of all door and window activities, enabling you to review past events and identify patterns or anomalies.
