Tuya Smart Motion Sensor - Wifi/Zigbee PIR Human Body Detection, Home Security & Automation, Battery Powered
MOES Tuya WiFi/ZigBee Smart PIR Sensor Human Body Infrared Motion Detector Home Security Scene Linkage Automation Battery Power
By Moes
Note Before Order!
1.There are two protocols of smart PIR sensor in this link: WiFi and Zigbee;
2.Zigbee smart PIR sensors
requireZigBee gateway, please purchase in addition;
3.Please choose and purchase according to the prompts on the photo,contact us online if you have any questions.
WiFi Smart PIR Sensor
Real-time Alerts from APP
Wide Detecting Range
Scene Linkage Adds Convenience
Scene Linkage Guards Security
Zigbee Smart PIR Sensor
Notice before purchase
NOTE: ZigBee gateway is required, please purchase in addition.
Check History Records
Records of motion or no motion status, as well as linkage logs, will be presented in the history records of MOES App to monitor the safety of your home in real time.
Right Place, Right Convenience
By placing smart sensors in different locations, changes in different locations can be monitored. At the same time, it supports linkage with smart devices to protect every corner of the home.
Easy Installation
You can use the provided stickers to stick it anywhere you need it, without the need for installation or wiring, or choose to place it directly where you need it, which is simple and efficient.
Customize Your Own Smart Scenarios
Seamless integration with smart home systems for automated responses to detected events.
When Motion/No Motion Detected
When a person is detected, a real-time notification will be sent to the mobile phone. Then, 30 seconds after no one is detected, a notification will be sent also. Different smart linkages can be performed according to the two states, such as the smart light automatically turns on when there is human motion, and automatically turns off when no human motion.
Dimensions
Smart PIR Sensors in Different Protocol
The ZigBee version has a shorter sensor response time, supports low power consumption, and has a longer battery life; while the WiFi version does not require any gateway. Please choose according to your needs.
Technical Specifications:
Battery: LR03-1.5V/AAA*2 (Alkaline battery)
Wi-Fi Standard: 2.4GHz
Wi-Fi Frequency: IEEE 802.11b/g/n
Standby Curent: 22uA
Alarm Curent: ≤ 45mA
Detect Angle: 128°
Detect distance:≤ 6 Meters
Packing List:
Smart PIR Sensor*1
Reset Pin*1
Sticker*1
Manual*1
