Tuya US Zigbee 3.0 Scene Switch Smart Central Control,4Inch Touch Build in Wireless Zigbee Hub, Work for Google Home Easy to Use
[Smart Home Control Center] - AVATTO P6E can control all smart switches,smart socket,smart sensor,smart light,smart curtain switch etc,as well as smart scene control in one touch.
[Build in Wireless Zigbee Hub] - 100+ Zigbee sub device can be added,economic and convenient.
[3 Gang Smart Touch Light Switch] - Built in 3 relays, support 3 gang light switch touch control physically and APP remote control.
[4 Inch HD Multi Touch LCD Screen] - Easy,convenient and smooth operation user experience for family members.
[APP Remote Control] - ONNDO P6EL can be controlled via smart life&Tuya Smart APP on your Phone/Tablet anywhere and anytime.
[Smart Device Sync Function] - All smart device in smart life/tuya smart APP in different protocol can be sync into the control panel.
[Family Share Function] - You can share the smart home center control panel to your family create a smart home together with your family member.
CPU:RK3308B Quad core Cortex-A35
OS:for Linux 4.4.143
RAM:DDR3 128MB
ROM:Flash 256MB
Screen:4 inch 480*480 Multi-touch
Bluetooth:BLE4.2 Single point
Wi-Fi:802.11b/g/n150Mbps 2.4GHz
Zigbee:802.15.4 PHY/MAC Zigbee network protocol stack
Light Switch:3 Gang Relay Switch
Light Switch Max Load:200W/Gang
Music Play:Built in 1W Mono speaker, custom local music source play, online music sources optional.
Light Sensor:Automatically adjust the screen brightness according to surroundings.
Zigbee Hub:Yes,100+ zigbee device can be added
Input:100-240VAC 50/60HZ 6A Max
Output:100-240VAC 50/60HZ 2A/Gang 6A/Total Max
Wireless Protocols:Wi-Fi, Bluetooth, Zigbee
Working Temperature:0℃ to +40℃
Working Humidity:5% to 90%RH(Non-condensing)
Bolt Hole Distance:83mm
Net Weight:186g
Colour:White
Material:Plastic
Package Contents:
1 * Smart Central Control
RAM:DDR3 128MB
ROM:Flash 256MB
Net Weight:186g
Colour:White
Material:Plastic
Package Contents:
