Tuya Wifi for Zigbee Temperature Humidity Sensor Smart Home Automation Indoor Thermometer LCD Display Works with Alexa Google
Description:
Higher Accurate Sensor Detection
Our temperature and humidity sensor is equipped with a built-in collector that provides exceptionally precise data for temperature and humidity in your surroundings. With the ability to monitor environmental changes every 30 minutes, this sensor guarantees ±0.3°C accuracy in temperature ranging from -10°C to 60°C (14°F to 140°F), and ±2%RH accuracy in humidity from 0% to 99%RH. This ensures accurate and reliable readings for your temperature and humidity monitoring needs.
Update the Data Automatically
With a sensitivity threshold of ±1℃ for temperature and 0.6% for humidity, any significant changes are reflected in the app. Additionally, you can manually refresh the data with single click of the reset button by a pin(included in the parcel), making it versatile for various applications.
Remote Monitor Your Room's Temperature and Humidity
Monitor the temperature and humidity in your room by Smart Life/Tuya Smart APP in real-time.
Convenient Voice Checking
Give a simple voice command to check the temp and humidity in your room/office via Alexa or Google Home assistant/Yandex Alice, especially when you are busy.
Lowe Power Consumption
It can autonomously provide data updates(48 times everyday) for up to 200 days, providing optimal performance and reliability.
(Please notice that whether the batteries are new. And the batteries are not included in the parcel.)
Smart Alert for Your Security
If the temperature is over 50℃,you will receive a notification from app,assisting you monitor your room environment and make it better.You can also set a smart scene for the security alert.
Make Your Home More Comfortable
Make a linkage to other Tuya smart devices,creating a smart scene to make you home more comfortable.
Tuya ZigBee Hub Required
A Tuya ZigBee hub is required for pairing.Then you can remote monitor and set smart linkage to other Tuya smart devices.
Easy to Install
Small, easy installation, and high reliability. You can install the sensor in the place you need.
SPECIFICATION
Type:Smart Thermometer
Standard:Wireless Hygrometer
Sensor: Thermal Resistor
Battery: AAA*2(NOT included in parcel)
Working Voltage: DC3V
ZigBee Standard:IEEE 804.15.4
Recommended Temperature Range: -10℃ ~+ 60℃(-40℉~+221℉)
Recommended Humidity Range: 5 %RH - 95 %RH
Temperature Detection Range:-10℃~+60℃
Humidity Detection Range:0%~99%
Temperature Sensitivity:0.3℃~1℃
Humidity Sensitivity:2%~3%
Voice Control: Alexa/Google Home Assistant/Yandex Alice
APP: Smart Life/TuyaSmart APP
Hub Requirement: Tuya ZigBee Hub
Warm Tips
1.Batteries are not include in the parcel due to the shipping restriction.
2.Tuya ZigBee Hub is required for pairing.
3.The temp. and humidity data will update automatically per 30mins.
5.If TuyaSmart app doesn't support Yandex Alice voice checking, please try to use Smart Life app.
6. If you put it in the fridge,please notice that the temperature range is -10℃~60℃.And the sensor is not waterproof.
