Tuya Wifi /Zigbee Smart Temperature Humidity Sensor Indoor Hygrometer Controller Monitoring Work with Smart Speaker Alexa Google
Tuya WiFi Smart Temperature And Humidity Sensor APP Remote Monitor For Smart Home var SmartLife Work With Alexa Google Assistant
Product Features:
1. High precision.
The sensor uses top suppliers. It can guarantee the high precision of the measurement data.
2. Real-time monitoring and recording.
The sensor will monitor the temperature and humidity in real time. You can view the changes in the value on the APP.
Record the temperature and humidity changes on the APP, and use the graphics to show you.
3. Scene linkage
The sensor can be used as the temperature and humidity data source of Tuya Smart, Smart Life, Amazon Alexa, Google Home. You can do many automated processes based on the data source.
4. Third-party voice support.
The sensor supports Amazon Alexa, Google Home Asistant. You can check the current temperature and humidity by voice.
Product Parameter:
Power Supply: LR03-1.5V/AAA*2(not included)
Wireless Type:Wi-Fi 2.4G / Zigbee 3.0
Temperature Measure Range: -20℃-60℃
Temperature Accuracy: ±1
Humidity Measure Range: 0% RH~99% RH
Humidity Accuracy: ±5% RH
Product package included:
1XSensor(Not include battery)
1xsticker
1xUser manual
NOTE:
1. The sensor is not always connected to WiFi, when it does not need a connection, it will close the WiFi connection.
2. The sensor connects to WiFi at least once an hour and reports data once.
3..Rechargeable 1.2V battery may cause inaccurate power measurement.
4. Zigbee version, Users must have/already bought a Tuya zigbee hub to operate. If without a zigbee hub, then such model will not work.
