Tuya Wifi/Zigbee Water Sensor Leakage Alarm Flood Leak Detector Smart Home APP Remote Control Smart Home Security Protection
$7.48
Color: 1Pcs(Need Gateway)
Notes: If you choose ZigBee Sensor, you need a Tuya ZigBee getaway to make it work.
Power input: AAA*2 (Not Included)
Communication protocol: Zigbee 3.0/2.4G WIFI
Material: ABS
App name: Smart Life/TUYA Smart
Description:
【Real-time detection】
A water immersion sensor that can detect water leakage in the environment in real time. When water immersion is detected, the detector will send an alarm signal to the host and report the information to the user's mobile phone. When the water level at the detection point reaches 0.5mm, the water intrusion sensor will report the water condition.
【Scene linkage】
The preset security scene is realized through the mobile APP. Once the monitored water level reaches the preset height, the alarm will be raised remotely. When the early warning water level is reached, the linkage gateway will send out a local sound and light alarm, and the mobile phone will receive the APP push reminder to let you know in time, and the mobile phone can close the water outlet by the remote electromagnetic valve.
【Multi-scene application】
The water leak detector can work normally in houses, hotels, shops, offices and apartments. Protect every moment.
Package Included:
1 *Tuya water sensor
1 *manual
