Tuya Zigbee 3.0 Door Window Sensor Smart Home Door Open Closed Detector Smartlife App Control via Alexa Google Home Zigbee2Mqtt
Tuya Zigbee 3.0 Door Window Sensor Smart Home Door Open Closed Detector SmartLife App Control Via Alexa Google Home Zigbee2MQTT
Dear Friends, please pay attention:
01 Without Battery: AAA*2 (not included)
02 With Battery:Built-in 1 CR2032 battery (non-rechargeable battery)
Description:
Input voltage::DC3V LR03*2
Standby current :≤10uA
Alarming current :≤15mA
Low-voltage notification :≤2.5V
Wireless Technology:ZigBee
Transmission Frequency:2.4GHz
Magnetic control distant : ≥15mm
Working temperature :-10-55℃
Working humidity :≤90%RH
1.Tuya Smart ZigBee Door&Window Sensor:A Tuya ZigBee Wireless Gateway Hub is a must to work with the door&window sensor,as well as a variety of ZigBee smart products.
2.Real-time remote monitoring:Whenever and wherever you are,once Door/Window Sensor detects external objects or animals, you will receive a notification by smart phone.
3.Wide Applications:Apply the smart door/window sensor to different scenes,your bedroom,garage,bathroom,garden and anywhere you like.
4.Battery powered for low power consumption;New designed with Low battery reminder supported.
5.Easy installation with double-side tape,simply stick it anywhere you like to protect your house security.
Package Included:
1*Zigbee Door Sensor
1*User Manual
Notes:
This product needs to be used with Tuya zigbee gateway
