Tuya Zigbee 3.0 Smart Temperature and Humidity Sensor Hygrometer Thermometer for Home Assistant via Zigbee2Mqtt
Limited Aliexpress Coupon Code, Input the code and Save Money!!!
ZigBee Smart Temperature and Humidity Sensor
ATTENTION
1. This product should work with Tuya Zigbee Hub, NOT work with Sonoff ZBbridge and ZBBridge PRO.
2. On the screen, the temperature unit only support Celsius ℃, NOT support Fahrenheit ℉.
3. AAA battery is NOT included in the package due to shipping limit.
Main Features
Monitoring temperature and humudity, show sync datas on App.
Intelligent inkage, turn on/off other smart device when temperature/humidity reach setting date.
High/Low temperature humidity Alarm when exceed the setting limits.
Self-stand design, easy to put it anywhere or paste on the wall.
Ultra low power consumption and long battery life.
Specification
Working Temperature : -10-55℃
Battery Type: 2*AAA Battery
Temperature Accuracy : + 0.3 degrees
Humidity Accuracy : + 3% RH
Certification: CE, RoHS
Package Content
1* ZigBee Temperature&Humidity Sensor
1* 3M double side tape
1* User Manual
