Tuya Zigbee 3.0 Wireless Scene Switch 4Gang 12 Modes Push Button Smart Home Remote Controller Automation Scenario Linkage Center
  • Four Independent Buttons: Each button on this 4-Gang Smart Switch can be programmed for single press, double press, and long press actions, offering up to 12 customiza..
  • Wireless and Battery-Powered: Eliminating the need for complex wiring, this Push Button Switch operates on a CR2430 3V button cell, ensuring a battery life of approxim..
  • Compact and Portable Design: Measuring 86 x 86 x 13 mm, the switch's sleek and minimalist design allows it to blend seamlessly into any home decor. Its magnetic backin..
  • Tuya Smart Integration: Compatible with the Tuya Smart platform, this switch enables effortless automation and control of various smart devices through the Smart Life ..
​Introducing the 4-Gang Smart Switch, a versatile and user-friendly device designed to enhance your smart home experience. This Zigbee 3.0 Scene Switch allows you to seamlessly control multiple devices and automate various scenarios with ease.​
  • Four Independent Buttons: Each button on this 4-Gang Smart Switch can be programmed for single press, double press, and long press actions, offering up to 12 customizable scenes. This flexibility enables personalized control over your smart home devices.​
  • Wireless and Battery-Powered: Eliminating the need for complex wiring, this Push Button Switch operates on a CR2430 3V button cell, ensuring a battery life of approximately two years. Its low power consumption and wireless design make installation straightforward and maintenance minimal.
  • Compact and Portable Design: Measuring 86 x 86 x 13 mm, the switch's sleek and minimalist design allows it to blend seamlessly into any home decor. Its magnetic backing provides the option to mount it on walls or use it as a handheld remote, offering flexibility in placement.​
  • Tuya Smart Integration: Compatible with the Tuya Smart platform, this switch enables effortless automation and control of various smart devices through the Smart Life App.
  • Simplified Control: With the ability to assign multiple functions to each button, you can effortlessly manage lighting, appliances, and other smart devices, creating a more intuitive and efficient home environment.​
  • Enhanced Automation: By setting up specific scenes, such as "Away Mode" or "Movie Mode," you can activate multiple devices simultaneously with a single press, streamlining your daily routines.
  • Easy Installation: The wireless nature of this Push Button Switch means no additional wiring is required. Simply attach it to any surface using the included adhesive or screws, and it's ready to use.
