Tuya Zigbee 3.0 Wireless Temperature and Humidity Sensor Works with Home Assistant Smart Life DIY Google Alexa Echo Automation
Note Before Order!
- The Coin Battery CR2032 is included in the box.
- Please contact us online if you have any questions, we are the manufacturer.
ZigBee Hub is Required
- Tuya ZigBee 3.0 Temperature and Humidity need work with Tuya ZigBee Hub, please make sure you already have a Tuya ZigBee Hub, if not, you can click the link in the picture below to buy the zigbee hub..
- This ZigBee Sensor can't work with other brands' ZigBee Hub, please make sure your ZigBee Hub is from Tuya.
Voice Enquiry
You can use voice commands to query the current battery level, temperature and humidity of the sensor.
Monitor the temperature and humidity of your home in Real-time
- Please make sure you already have a Tuya ZigBee Hub, it's a must for all the Tuya/Smart Life ZigBee devices.
- Free App Name: Smart Life, or Tuya App
You can check the Temperature and Humidiy in Smart Life App
Automation Function
After you set the automation in the app, you can control the air conditioner(You need buy the extra Wifi IR remote in our store)and wifi humidifier in your home
Specification
Colour: White
Wireless Protocol: Tuya ZigBee 3.0(can just work with Tuya ZigBee Hub, it can't work with other brands' Hub)
Control Distance: 10~30 meters around the Tuya ZigBee Hub
Battery Type: Coin Battery CR2032(included in the box)
Please be noted the Tuya ZigBee Hub is not included in the box if you don't buy it.
We have all the accessories you need in the box, you don't need to pay extra cost.
What's in the box?
1 * Tuya ZigBee Temperature and Humidity Sensor(Depends on your choice)
1 * Coin Battery CR2032(in the sensor)
1 * Wall Bracket for Sensor
1 * Screw Driver
1 * Screw Kits
1 * Double-Sided Tape
1 * Ejection Pin
1 * User Guide
Why us?
1) We are ISO9001 certified manufacturer, high quality with competitive price.
2) We are responsible, popular and TOP Brand.
