Tuya Zigbee Addressable COB LED Strip Light Kit RGBIC WS2811 High Density SPI Flexible Smart Tape Lamp Room Decor 5M 10M 20M 25M
$123.65
Emitting Color: 1M White Pcb Rc1
  • ▫️ Dot-Free Illumination: 720 LEDs/m COB technology provides smooth linear light without dark spots compared to old SMD strips
  • ▫️ Addressable Dream Color: WS2811 IC architecture allows 160 million colors, rich dynamic chasing modes, and customized DIY lighting effects
  • ▫️ Smart Ecosystem Sync: Full integration with Tuya, Smart Life, Alexa, Google Assistant, and Philips Hue for responsive voice control
  • ▫️ Stable Mesh Connection: Zigbee connection offers zero lag response, ultra-stable signal, and supports multi-group controller synchronization
  • ▫️ Music & Timing Function: Built-in high sensitivity microphone syncs lights to your favorite music rhythm. Features scheduled automatic on/off timers
Warning:
Never turn on the LED strip while it is still coiled on the reel or kept coiled for a long time, as heat cannot dissipate properly and this may cause the LED strip to overheat and burn out!
Notice
1. Please re-set the pixel number in the APP before using, if not set the pixel number, the led strip may not work properly (the pixel number = length*20, for examle: 10m led strip is 10*20=200).
2. If you find the R/G/B wire sequence of the led strip is different from the controller, you can reset the R/G/B sequence in the APP.
If you don't know how to reset it, can ask us for help.
🌟【Product Overview】
Premium high-density smart chasing color LED strip kit designed for ambient home decoration, ceiling lighting, and commercial showroom setup for global smart home enthusiasts.
🚀【Key Features】
  • ▫️ Dot-Free Illumination: 720 LEDs/m COB technology provides smooth linear light without dark spots compared to old SMD strips.
  • ▫️ Addressable Dream Color: WS2811 IC architecture allows 160 million colors, rich dynamic chasing modes, and customized DIY lighting effects.
  • ▫️ Smart Ecosystem Sync: Full integration with Tuya, Smart Life, Alexa, Google Assistant, and Philips Hue for responsive voice control.
  • ▫️ Stable Mesh Connection: Zigbee connection offers zero lag response, ultra-stable signal, and supports multi-group controller synchronization.
  • ▫️ Music & Timing Function: Built-in high sensitivity microphone syncs lights to your favorite music rhythm. Features scheduled automatic on/off timers.
  • ▫️ Cuttable & Flexible: Strong self-adhesive back tape allows easy bending. Can be cut every 50mm at marked lines for exact custom fitting.
📐【Specifications】
  • 🔹 Strip Width: 12mm
  • 🔹 Strip Thickness: 2.5mm to 3.0mm
  • 🔹 LED Quantity: 720 LEDs per meter
  • 🔹 PCB Color Available: White / Black
  • 🔹 Power Consumption: 15W per meter
  • 🔹 Color Rendering Index (CRI): RA > 90
  • 🔹 Lighting Color: SPI RGB IC (Chasing Color)
  • 🔹 IC Type: WS2811 IC (1 IC controls 5cm strip, 20 ICs/m)
  • 🔹 Minimum Cut Unit: 50mm
  • 🔹 Control Range: 30 Meters (2.4G Remote Handle)
  • 🔹 Controller Feature: Power-off State Memory Function
📦【Package Includes】
  • 🎁 For 1M - 5M Kit: 1 x COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 1 x Power Adapter.
  • 🎁 For 10M Kit: 1 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 1 x Power Transformer, 1 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.
  • 🎁 For 20M Kit: 2 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.
  • 🎁 For 25M Kit: 2 x 10M COB LED Strip + 1 x 5M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.
  • 🎁 For 30M Kit: 3 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.
🔧【How to Use】
  • 📌 Step 1: Connect the LED strip to the Tuya Zigbee controller matching the arrow marks carefully.
  • 📌 Step 2: Connect the controller to the included power transformer/adapter, then plug into your wall outlet.
  • 📌 Step 3: Turn on your Tuya Zigbee Gateway, pair the controller in the Smart Life App, and enjoy smart lighting.
🛑【Important Notes】
  • ❗️ Gateway Required: This kit does NOT connect to WiFi directly. A compatible Tuya Zigbee Gateway Hub is strictly required.
  • ❗️ Heat Warning: Never light up the LED strip while it is tightly wound on the plastic reel. Unroll completely before powering on.
  • ❗️ Voltage Alert: Never connect the LED strip or controller directly to AC 220V mains power. Always use the provided power transformer.
  • ❗️ Direction Indicator: Pay close attention to the print arrows on the strip when connecting. Reversing the input direction will burn the IC chips.
  • ❗️ Extension Wire: If your transformer is far from the strip head, you must prepare an extra 2-pin extension cable yourself.
  • ❗️ Remote Battery: The 2.4G remote handle requires batteries which are not included due to international shipping regulations.
💬【FAQ】
  • Q1: Can I connect this LED strip kit directly to my home WiFi router without a hub?
    • 💡 A1: No. This is a Zigbee version kit. You must have a Tuya Zigbee Gateway hub to connect it to the Smart Life or Tuya App.
  • Q2: Does the package include everything needed for quick installation?
    • 💡 A2: Yes, it is a plug-and-play complete kit. However, if the transformer is far from the light strip, you need to buy a 2-pin extension cable. Remote batteries are also not included.
  • Q3: Can I cut the light strip and use it to turn a 90-degree corner on my wall?
    • 💡 A3: Yes. The strip can be cut every 50mm. Kits above 10 meters include a free 90-degree L-shape corner connector for tool-free corner installation.
  • Q4: Is it safe to leave the light strip turned on while it is inside the packaging box or reel?
    • 💡 A4: Absolutely not. Lighting the strip while rolled up causes extreme heat accumulation and will burn out the LEDs and IC chips instantly. Always unroll it first.
  • Q5: Is this light strip kit suitable for outdoor garden or bathroom illumination?
    • 💡 A5: No. This kit is designed for indoor decoration lighting such as living room ceilings, bedroom walls, and commercial displays. Keep away from water.
About the remote:
Certificates
About Cooleeon Company
SHENZHEN COOLEEON ELECTRONICS CO., LTD. was founded in 2012, who is a professional manufacturer of COB LED products.Our products ranges from indoor & outdoor lighting, car lights, truck lights, traffic lighting, decoration lighting, plant grow lights to high power LED etc. We also supply OEM & ODM service to design & produce customers’ own special products.
As a professional COB LED supplier, Cooleeon has excellent teams who focus on product development & design, quality control & inspection and company running. We own a 5,000 square meters factory with 30 automatic production lines and more than 100 staffs,daily output reach to 5,000,000 pieces, who is one of the largest COB manufacturer in China.
“Quality first” is always Cooleeon People’s NO.1 goal. In order to supply high quality products and services, Cooleeon has built a modern quality management system which is in strict accordance with international standards. Till now, Cooleeon’s products have been sold to more than 100 countries & district, main market including North America, Europe, Middle East, Japan, Korea, Southeast Asia, South America etc. We also have gained very good public praise and feedback from out customers.
If you have any new ideas or concepts for the products, please contact us. We are glad to work together with you and finally bring you the satisfied products.
