TUYA Zigbee Constant Current CCT LED Driver Dimmable Power Supply LED Strip Controller 12W Transformer for Alexa Smart Life APP
$82.52
TUYA Zigbee Constant Current CCT LED Driver Dimmable Power Supply LED Smart Controller 12W Transformer For Alexa Smart Life APP
MODEL NO:PB-12A-2(WZS)
● Tuya APP cloud control, support color temp and brightness adjust, delay turn on/off,timer run, scene edit, sleep wake-up functionand biorhythms (APP control sound control needs to match the ZIGBEE gateway.)
● Voice control, support for Amazon Alexa, Google Assistant,Tmall Genie and Xiaodu smart speaker
● Can relay and route to each other, up to 15 hops
● Match with Zigbee 3.0 remote or scene panel control optional
● Reset key for clearing network connection
● Universal AC input / Full range
● Flicker-free
● 2 channel constant current output, congurable current via DIP switch
● Over-load / Short circuit protection, recover automatically
● Full protective plastic case
● Suitable for indoor LED lighting application
● 5 Year, 50,000hr warranty
Applications
● Suitable for downlight, spotlight and decorative applications.
● Ofce / Commercial / Domestic Lighting, Hotels, Classrooms, Warehouse, Health care, Retail and Display.
● Use for retrot upgrades & new luminaire designs
App Operating Instructions
1. Network pairing
● Download the Tuya APP and register anaccount, search and add the Tuya Zigbee gateway device
● Quickly press the "RESET" button five times or repeat power on and off five times to clear the previous network connection,enter pairing mode with the output light breathes blinking.
● Under the gateway, search and add new device. If the network connection is successful, you can find ZBS-CCT devices in Tuya APP.
2. Lighting control settings
●After pairing the light device, click the device and change brightness and color temperature by touch brightness slide and color wheel.
●In “Scene”, there are 4 scene can be recalled or customized.
●In “Setting”, there are Plan, Schedule, Timer, Rhythms, Power-on behavior functions.
widely used
