Tuya Zigbee Door and Window Magnetic Sensor Smart Life APP Security Detector Alarm Remote Monitor Works with Alexa Google Home
Notes: Please be clear before purchase, this product needs to be used with a zigbee3.0 gateway
1.The latest Zigbee3.0 connection method provides the most stable performance and the lowest power consumption.Battery powered ,new designed with hall sensing technology and tamper protection;Low battery reminder supported.
2.APP Real-time remote monitoring:Whenever and wherever you are,once Door/Window Sensor detects external objects or animals, you will receive a alarm notification by smart phone. Keep your house safe all the time.
3.Wide Applications:Apply the smart door/window sensor to different scenes,your bedroom,garage,bathroom,garden and anywhere you like,keeping your whole house away from danger with a linkage of the smart door/window sensor.
4.Smart Linkage: You can link it with other graffiti devices. For example, when the door is opened, the light bulb comes on. When the door is closed, the bulb turns off. Make your life more convenient
Product name :Door magnetic sensor
Networking form :Zigbee
Detection :<5mm
Powerinput :CR2032 buton battery(Can be used for more than one year)
working temperature:-10°C~45℃
Product size:50mm*25mm*11mm
