Tuya Zigbee Human Presence Sensor Smart Motion Detector with 24Ghz Mmwave Radar for Home Security Supports Smart Life APP
GIRIER Tuya ZigBee Human Presence Sensor Smart Motion Detector with 24GHz mmWave Radar for Home Security Supports Smart Life APP
Safe, Convenient, Better Home
ITEM DESCRIPTION
Remote Monitor Your Space Efficiently
GIRIER's smart human presence sensor revolutionizes home security, convenience, and energy savings. With its 24GHz mmWave radar detector and 120° wide detection range, it detects moving objects—day or night. Monitor your spaces efficiently via the Smart Life app.
24GHz mmWave Radar Detector
Compared to a PIR motion sensor, the human presence sensor equipped with a 24GHz mmWave radar detector can be activated by a wider range of conditions, including breathing, heartbeat, subtle movements, and even when humans are stationary. As long as the human presence sensor detects either stationary or moving humans, the light will remain on, regardless of whether you are reading or using the restroom.
Instant Alerts
Receive instant app notifications when our mmWave radar sensor detects motion or presence state. What's more, you can also check the distance between the sensor and the detected object in real-time.
Safeguard Your Family
Suitable for elderly care, GIRIER human presence sensor tracks behaviors like movements and stationary states as sleeping etc. Alert you presence or absence states in real-time, so as to promptly detect abnormal situations.
Adjustable Detection Range & Sensitivity
Easily configure your human presence sensor to a detection range of 1.5 meters to 6 meters, as well as adjust the sensitivity to low, medium, or high.
Customized Home Automation, Simplify Life
Automate your smart home with "IF" and "THEN" conditions in the Smart Life app using the GIRIER ZigBee sensor. This seamlessly integrates with various devices for a smooth experience. For instance, our 24G mmWave radar sensor will trigger the smart siren to alert you if your baby nears stairs or sills. Plus, set a Departure Mode to turn off lights and save energy while safeguarding your home. Enjoy total smart home control with ease.
Warm Tips:
1. Don't support voice checking.
2. Tuya ZigBee Hub is Required when using.
3. Please note that if you set high sensitivity, the subtable movements as aireflow will also be detected. We suggest you to set in "low" status if you want it to detect the human motions.
4. It cannot distinguish the human and the object.
High-tech 24GHz mmWave Radar Detector
Adjustable Detection Range and Sensitivity
Protect Your Baby
Trigger the siren to remind you if your baby is close to the dangerous area.
RECEIVE INSTANT ALERTS WHENEVER MOTION IS DETECTED
Configure Different Smart Scenes
Link this smart human movement and motion sensor to other Tuya smart devices.
Convenient your life, protect your home.
Convenient Your Life
Upon entering the bathroom, the lights automatically turn on, and they turn off once the human presence sensor detects no one.
No any camera record, protect your privacy.
7 Days Record Checking
Differences Between 24GHz mmWave Radar Sensor and PIR Sensor
SPECIFICATION
Packing List
1*ZigBee Human Presence Sensor
1*Type-C Cable
1*User Manual
SPECIFICATION
Type: ZigBee Human Presence Detector
Input Power: Type-C 5V1A
Cable Length: 45cm
Cable Type: Type-C
Detection Sensor: 24GHz mmWave Radar detector
Maximum Detection Distance: 6m
Horizontal Detection Angle: 120°
Vertical Detection Angle: 120°
Operating Temperature Range: -10℃-60℃
Operating Humidity: ≤95%RH
WiFi Standard: IEEE 802.11b/g/n 2.4GHz Only
ZigBee Standard: IEEE 802.15.4
Mounting: Adhesive
Hub Requirement: Yes
APP: TuyaSmart/Smart Life
