Tuya Zigbee Intelligent Soil Moisture Meter Temperature &Humidity Tester Plant Monitor Detector Garden Planting for Google Alexa
  • Accurate Measurements: Equipped with high-sensitivity stainless steel probes, it delivers precise readings of soil moisture (0-100%) and Temperature Meter (-20℃ to 60℃..
  • Wireless Connectivity: Utilizing Zigbee 3.0 protocol, it seamlessly connects to the Tuya Smart app, allowing you to monitor soil conditions remotely and receive real-t..
  • Smart Home Integration: Compatible with Google Home and Alexa, enabling voice control and automation within your smart home ecosystem
  • Durable Design: With an IP67 waterproof rating, it withstands various environmental conditions, making it suitable for both indoor and outdoor use
Introducing the Tuya Zigbee Intelligent Soil Moisture Meter, a cutting-edge device designed to monitor and maintain optimal soil conditions for your plants. This Intelligent Plant Monitor Detector provides real-time data on soil moisture, Temperature Meter, and humidity, ensuring your garden thrives effortlessly.
  • Accurate Measurements: Equipped with high-sensitivity stainless steel probes, it delivers precise readings of soil moisture (0-100%) and Temperature Meter (-20℃ to 60℃) with an accuracy of ±1℃.
  • Wireless Connectivity: Utilizing Zigbee 3.0 protocol, it seamlessly connects to the Tuya Smart app, allowing you to monitor soil conditions remotely and receive real-time updates.
  • Smart Home Integration: Compatible with Google Home and Alexa, enabling voice control and automation within your smart home ecosystem.
  • Durable Design: With an IP67 waterproof rating, it withstands various environmental conditions, making it suitable for both indoor and outdoor use.
Simply insert the Zigbee Garden Soil Humidity Tester into the soil of your potted plants, vegetable gardens, or lawns. The device will transmit real-time data, including soil moisture and Temperature Meter, to your smartphone via the Tuya Smart app. You can monitor historical trends and set up automated irrigation systems. By maintaining optimal soil conditions, you enhance plant health, prevent over or under-watering, and promote robust growth.
Specifications
  • Material: Plastic and 304 stainless steel
  • Power Supply: 2 x AA batteries (not included)
  • Communication Mode: Zigbee
  • App Data Response Time: 60 seconds
  • Dimensions: 180 x 47 mm
Upgrade your gardening experience with the Tuya Zigbee Intelligent Soil Moisture Meter, ensuring your plants receive the care they deserve with the help of modern technology.
