Tuya Zigbee Intelligent Wireless Door and Window Alarm Sensor Intelligent Linkage Sensing ZIGBEE Door Magnetic Alarm Smart Life
Tuya zigbee intelligent wireless door and window alarm sensor Intelligent linkage sensing ZIGBEE door magnetic alarm smart life
The Doodle zigbee door status sensor must be used together with the Doodle zigbee gateway!!!
Product name: Doodle zigbee door magnet
Material: ABS
Battery: DC3V LR03 (without battery)
Detection accuracy :<15mm
Standby time: Battery life of 3 years, press 5 times a day
Standby current :≤45uA
Wireless mode :2.4GHz
Protocol :ZigBee 3.0
Weight :45g
Size (body) :L70*W21*H11mm
Size (auxiliary body) :L44*W15*H11mm
Instructions for use:
Press and hold the reset button with the pin for more than 6 seconds until the front indicator blinks and the indicator blinks, then you can enter the distribution mode
Applicable location: door/window/cabinet, etc
Installation position: External
Supported system :Android/IOS
Working environment: indoor
Operating temperature :-10°C~40°C(14°F ~ 104°F)
Storage temperature :-10 ° C ~60 ° C (14°F~140°F)
Working humidity :20% ~85% RH
Storage humidity :0% to 90% RH
Connection mode: Zigbee connection
Voice control: Support Tmall Genie, Google Assistant, Alexa, Baidu Xiaodu and other third-party voice platforms
Compatible gateway: Doodle zigbee gateway, HUE gateway above 3.0
