Tuya Zigbee Smart Home Temperature and Humidity Sensor with LED Screen Works with Google Assistant and Tuya Zigbee Hub
Tuya Smart ZigBee Temperature and Humidity Sensor Indoor Hygrometer Thermometer Detector with Digital LCD Display Smart Life APP Remote Control ZigBee Gateway Required
By Moes
Main Features:
1.New ZigBee smart temperature and humidity sensor is designed with Tuya ZigBee hub required for APP configuration and other smart controls in Tuya Smart APP,and the Tuya ZigBee gateway performs as the center bridge for whole Tuya ZigBee devices,which is highly recommended than other hubs for its compatibility.
2.Extremely lower cost than our first generation with real-time accurate perception of house temperature and humidity,together with clear digital LCD display.Smart automation is functional well with other smart devices as electric heater and humidifier for whole house linkage,even with effective period optional for more flexible controls.
3.Battery level is shown on the LCD display with accurate battery condition in APP meanwhile,together with low battery alarm and Temp. unit convert between ℃ / ℉ for easy reading to your own need.(Note:Two types optional as the round and square type)
4.The intelligent guardian mode with facial expression can improve the indoor environment according to the temperature and humidity value, and care for the healthy growth of the baby to a large extent with comfort indicator in Smart Life APP.
5.Extremely mini size featured,together with two placement methods as table place and wall-mounting mode for simple installation and usage;includes full 2-year warranty and 60-day refund guarantee for complete satisfaction.
Product Name:ZigBee Temperature Humidity Sensor
Wireless protocol:ZigBee
Temperature measurement range: -10℃~50°C
Humidity measurement range:0%-99%RH
Working voltage:DC2.4V-3V
Battery specification:CR2032 button cell
Product size:φ60×16.7mm(ROUND)/16.7×60×60mm(SQUARE)
Screen size:φ46.5mm(ROUND)/46.5×46.5mm(SQUARE)
Product net weight:42g(ROUND)/49.5g(SQUARE)
Package List:
Temperature Humidity Sensor×1
Product manual×1
Wall sticker×1
User Manual:
Round:https://drive.google.com/file/d/1WBQWePAzKxfONMbSraebUrZU36264TPI/view?usp=sharing
Square:https://drive.google.com/file/d/1WGQuAuIRCdCOXEbn-nnBJ0rVyqOcI7sA/view?usp=sharing
Q&A:
1.Q:Is there the comfort indicator displayed in the sensor itself?
A:No,the comfort indicator is featured in APP to tell the temperature and humidity level.
2.Q:Can I read the data history for house temperature and humidity?
A:Yes,there is the data graph for humidity and temperature with day,month and year recorded.
3.Q:Is the sensor hub required for APP configuration?
A:Yes,it is the ZigBee type that is Tuya ZigBee gateway required.
4.Q:Can I remotely monitor the house temperature when I am not at home?
A:Yes,it is compatible with Tuya Smart APP for wireless remote control.
5.Q:Does it support the Temp. unit switchable?
A: Yes,you can covert ℃ and ℉ easily in APP for easy reading.
