Tuya Zigbee Smart Knob Dimmer Scene Switch Wireless Rotary Controller Works Alexa Google Home Smart Life App
$12.69
Color: 1Pc(Need Gateway)
Attention please:
This is the Zigbee version and requires a gateway for connection!!!
Why buy?
1.【Two-in-one device for wireless scene】In the scene mode, the button respectively support single click, double click scene requirements. You don't need to click the scene mode on your phone, just click the ZigBee smart remote control to open the smart scene.
2.【Wireless control of ZigBee dimming lamp in remote mode】Add an intelligent knob switch in tuya intelligent ZigBee gateway, and then add an intelligent ZigBee light bulb under the remote dimming interface in the App, so you can remotely control your lamp wirelessly. (Note: Only ZigBee lamp can be added for control)
3.【Four operations under remote mode to meet different demands】Single press to ON/OFF the bulb,rotate to normal dimmer,press and rotate to set the color temperature,and long press more than 3 seconds to set color,which clarifies the real-sense of value for money with this mini excellent device.
4.【Create multiple intelligent scenes for ewelink smart devices in App under scenario mode】To create any smart automation as you want on your smart phone app to start your another intelligent lifestyle, when you are tired from one-day work,such as home mode, waterproof level up to IP55 for wider applications.
Q&A
1.How to connect products?
This product connection requires Tuya zigbee gateway, the gateway is powered on, the product on the battery, the product should be as close as possible to the Zigbee smart gateway, and then long press the product reset button for 6 seconds until the indicator light flashes quickly, open the smart life or Tuya APP, click on the upper right corner of the “+” sign, click on the add device, and wait for the search to be added!
Specifications
Item: Zigbee smart knob scene switch
Wireless Protocol: Zigbee (need zigbee gateway)
Working Voltage: 3V
Standby Current: ≤8uA
Battery Type: CR2450(include battery)
App: Smart Life / Tuya Smart
Working Temperature: -10°C~55°C
Working Humidity: ≥90%
Weight:58g
Packing List:
Knob*1
Manual*1
Sticker*1
