Tuya ZigBee Smart Knob Switch Wall Scene Switch Push Button Battery Powered Automation Scenario Remote Panel Smart Life App
  • Hign-concerned Chemical: None
  • Current: 1A
  • Material: plastic
  • Switch Type: Knob switch
  • Model Number: ZigBee Smart Knob Switch
  • Current: 1A
  • Material: plastic
  • Features: Zigbee Automation Scenario Switch
  • Item Type: SWITCHES
  • Brand Name: coolo
  • Is Smart Device: YES
  • Origin: Mainland China
  • Certification: UL,RoHS,LVD,CE
  • Power supply: Battery CR2450 3V DC
  • Feature 1: Create intelligent scenes
  • Note: Pair with ZigBee gateway
  • Wireless Protocol: Zigbee 3.0
  • Life of battery: 2 years (General use)
  • Smart home platform: Tuya
  • Support: Zigbee2MQTT
Note: Intelligent linkage to tuya smart devices for normal use only, can not be used alone without tuya smart device; Need to be used together with ZigBee gateway.
Item: Tuya Zigbee smart knob scene switch
Wireless Protocol: Zigbee (need zigbee gateway)
Working Voltage: 3V
Standby Current: ≤8uA
Battery Type: CR2450(include battery)
App: Smart Life / Tuya Smart
Working Temperature: -10°C~55°C
Working Humidity: ≥90%
【Two-in-one device for wireless scene】In the scene mode, the button respectively support single click, double click scene requirements. You don't need to click the scene mode on your phone, just click the ZigBee smart remote control to open the smart scene.
【Wireless control of ZigBee dimming lamp in remote mode】Add an intelligent knob switch in tuya intelligent ZigBee gateway, and then add an intelligent ZigBee light bulb under the remote dimming interface in the App, so you can remotely control your lamp wirelessly. (Note: Only ZigBee lamp can be added for control)
【Four operations under remote mode to meet different demands】Single press to ON/OFF the bulb,rotate to normal dimmer,press and rotate to set the color temperature,and long press more than 3 seconds to set color,which clarifies the real-sense of value for money with this mini excellent device.
【Create multiple intelligent scenes for ewelink smart devices in App under scenario mode】To create any smart automation as you want on your smart phone app to start your another intelligent lifestyle, when you are tired from one-day work,such as home mode, waterproof level up to IP55 for wider applications.
