Tuya Zigbee Smart Mini LCD Temperature Humidity Sensor APP Remote Control Thermometer via Smart Life for Smart Home for Alexa
Tuya Zigbee LCD Temperature Humidity Sensor APP Remote Control Thermometer via Smart Life For Smart Home Work With Alexa google
Description
• LCD Display:The thermometer has an LCD display that shows the temperature and humidity levels.
• ZigBee Communication :The thermometer uses ZigBee communication to connect to your home network and send data to your phone.
•Air omfort indicator: Level icons indicate air comfort, great for monitoring family's living conditions and health.
•Clear reading: large numbe, allowing easy readability.
Product parameter
Input voltage: DC3V CR2032
Static current: ≤20uA
Working current: ≤15mA
Low voltage: ≤2.5V
Zigbee: IEEE 802.15.4
Detection temperature: -9.9℃~+60℃
Detection humidity: 0-99%RH
Installation mode: Wall mount/Place desk
Operating temperature: -9.9℃~+60℃
Operating humidity: Maximum 99%RH
Dimensions:52x42x12mm
Note
* Do not use in humidity over 90% for a long time.
* This product is Zigbee version, Users must have/already bought a tuya zigbee hub to operate. If without a zigbee hub, then such model will not work.
* Data Interval:30S(A deviation of more than 0.5 degrees Celsius in temperature or 5 percentage points in humidity is detected).
Package Contents
1x Zigbee Temperature Humidity Sensor(No Battery )
1x Adhesive Pads
