Tuya Zigbee Smart Soil Tester Humidity Temperature Moisture Sensor App Monitor for Plant Garden Work with Home Assistant Z2M
Tuya Zigbee Smart Soil Tester Humidity Temperature Moisture Sensor App Monitor for Plant Garden work with Home Assistant Z2M
Note:
1. Before installing this product in the ground, be sure to cleanup the outer surface of the device.
2. Insert soil moisture sensor in the ground not less than 2/3. Ensure maximum exposure to the topside of the unit. Check for absence of water on a soil moisture sensor.
Specification
Item: Zigbee Soil Moisture Sensor
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Soil Moisture Range: 0%~100%
Indicator: lights up when 3%
Temperature Resolution: 0.1℃
Humidity Resolution: 1%
Temperature Measurement Accuracy: ±0.5℃
Humidity Measurement Accuracy: ±5%
Working Voltage: DC3V
Standby Current: ≤20uA
Battery Type: AAA Battery *2pcs (not included)
1. Made of PC and ABS material, with high impact resistance, heat resistance, low temperature resistance, nice chemical resistance and electrical properties.
2. High accuracy, support the detection of the humidity and ambient temperature in the soil of green plants, lawns, etc.
3. BT connection, BT 4.1 version, support for both iOS and Android system.
4. Cellphone APP control, accurate readings, so that users know the specific situation of the soil at any time, to solve the traditional temperature and humidity is not easy to read the problem.
5. Mobilephone APP displays the soil temperature and humidity in the detection, and the indicator lights up when 3%.
6. The upper LED indicator is designed to remind users to water in time.
7. Multifunctional design, statistical temperature and humidity function with low battery reminder.
8. Multi-scene application: plug and plays, suitable for indoor potted plants, green plants, greenhouse, etc.
