Tuya Zigbee Smart Window Door Gate Sensor Detector, Smart Home Security Alarm System Smart Life Tuya App Wireless Remote Control
Tuya ZigBee Smart Window Door Gate Sensor Detector Smart Home Security Alarm System Smart Life Tuya App Remote Control Real-time Monitor
Note: The battery is not included
Main Features:
1. Tuya Smart ZigBee Door&Window Sensor:
A Tuya ZigBee Wireless Gateway Hub is necessary to work with the door&window sensor,as well as a variety of ZigBee smart products, which realizes the whole intelligent linkage to home.
Simply add the sensor into the ZigBee hub in the Smart Life/Tuya App.
2. Real-time remote monitoring:
Whenever and wherever you are, you will receive the notification in smart phoneonce Door/Window Sensor detects external objects or animals.
Keeping the house safe all the time.
What you need to do is to keep your sensorconnectingwith ZigBee hub .
3. Wide Applications:
Apply the smart door/window sensor to different scenes, bedroom, garage, bathroom, garden and anywhere you like ,keeping your whole house away from danger with a linkage of the smart door/window sensor,together work with various of zigbee sensor in the zigbee hub. Easy to integrate into various of environments.
4. Battery powered for low power consumption.
New designed with hall sensing technology and tamper protection.
Low battery reminder supported.
5. Easy installation with double-side tape,simply stick it anywhere you like to protect your house security.
Make intelligent linkage with other smart devices to achieve a comprehensive idea of intelligence
Wireless Technology : ZigBee
Working Voltage : 2.4V-3.3V (CR2032 battery)
Transmission Frequency : 2.4GHz
Working Temperature:‒20°C ~+60°C,0%~95%RH
Transmission Range : Indoor :10~30m/ Outdoor :30~50m
Size Main Body : 40*26*13mm
Size Small Body : 26*11*9.5mm
Package list:
Sensor*1 +User Manual*1
Applied To Keep Your House Safe
Open/Close Log In 7 Days
A long period of door open/close record supports to be checked at any time of the
changes in the past 7 days of the family, with intuitive time recording.
Low Battery Reminder
If battery capacity is low, the sensor will push notification by
App to remind you to replace the battery in time.
Reminder For Door Open/Close
You can choose to receive reminder for door open/close according to your own
needs, to make sure you won't be bothered by frequent notifications.
Home Security Guardian
Helps you understand what's going on in your home, especially if there are children and pets
in the house, while also keeping your belongings safe.
Precautions For Installation Aad Use
With adhesive tapes on the back, the door/window sensor can be sticked to
anywhere you need.
Family Sharing
Easy operation in App can help share the device with your family to monitor
connected devices together.
APP Configuration
| 1. Open the Smart home APP and click "+" in the upper right comer to add the door magnetic sensor | 2. Long press the reset button for 5 seconds until the screen light flashes for 3 times and then it is released | 3. After successful addition, add other only devices according to APP prompt |
Multi-scene application
Suitable for home, shop, office, factory and other different scenes
Intelligent linkage scene
When there is no one in the home, strangers break in , gas leakage or other safety hazards can not be ignored,you could
open smart home mode, comprehensive detection at home protecting family members safety and property
When you go home at night, opening the door , the living room lighting automatically open, curtains closed,
do not search the switch in the dark
| Advanced Manufacturing Process Multiple Safety Protection | |||
| Overflow Remind | Security Guard | Water Proof | Quality Certification |
| IP66 grade water proof material, the internal use advanced welding technology, through a series ofquality certification, stable and reliable performance. |
Parameter
40 mm * 26mm * 13mm + 26mm * 9.5mm *11mm
