Tuya Zigbee Soil Moisture Sensor 3 in 1 Humidity Temperature Sunlight Meter Screen/App Control for Plants Pots Garden
Item Type: Soil Temperature Humidity Sunlight Meter for Plant Pot Garden
Temperature range: 0-60°C (32°F-140°F)
Humidity range: 0-100%
Light: 5 levels (0-1000 lux LOW-1000-2000 lux LOW; 2000-5000 lux NOR5000-6000lux High; 6000-7000 lux High+)
Protoco: Zigbee
Description
Tips:
1. Tuya Zigbee version must work with Tuya Zigbee gateway .Our Tuya Zigbee version is best choice for Tuya system, others Zigbee 3.0 version doesn't support Tuya.
2. Record date within 365 days. Change ℃ or ℉ by button on surface. Low power warming.
3. Support Tuya, Smart Life, etc.
4. For Soil Only, please don't use it test water.
Note:it work with home assistant via zigbee2mqtt
Tuya Zigbee Soil Moisture Sensor Temperature Sunlight Humidity Meter Screen/APP Control for Plants Pots Garden with LCD Display
🌱Smart Tester: If you have Hoaozee soil tester and water timer at same time, you could set a smart irrigation system. When the tester and timer controlled by same gateway, set a programmer to let timer on or off according to the data from soil meter automatic.
🌱Reliable Performance: The temperature & humidity & sunlight 3 in 1statistics function, low battery reminder, and reading on mobile phone apps or LCD display allow users to constantly understand the specific situation of the soil, solving the problem of inconvenient traditional temperature and humidity readings.
🌱Switching Between °C and °F: Choose your preferred reading unit, Fahrenheit or Celsius. Just click the round button on surface. Long press the button to use for distribution network.
🌱Check Humidity and Temperature: You could check Moisture and Temperature in anywhere and anytime. Our sensor can record those dates within 365 days.
Specification:
Protoco: Zigbee
APP: Smart Life
Battery: 2*AAA alkaline batteries (not included)
Package List:
1 x Soil Temperature Humidity Sensor
1 x Manual
