Tuya Zigbee Soil Moisture Sensor Temperature&Humidity Thermohygrometer Garden Automation Irrigation Detector for Alexa Google
Specification
Item: Zigbee Soil Moisture Sensor
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Soil Moisture Range: 0%~100%
Temperature Resolution: 0.1℃
Humidity Resolution: 1%
Temperature Measurement Accuracy: ±0.5℃
Humidity Measurement Accuracy: ±5%
Working Voltage: DC3V
Standby Current: ≤20uA
Battery Type: LR03AAA Battery *2pcs (not included)
App: Smart Life / Tuya
Water shortage warning: when the soil reaches a satus of water shortage,the mobile app sends out a water shortage alert you that it's time to water.
Real-time detection of status changes:air temperature/humidity value/soil moisture.
Wide range measurement:the plant sensor humidity range can reach 0~100%, which can help to quickly identify the soil moisture content and accurately judge whether your plants need watering.
App remote control: remote real-time monitoring of soil temperature and humidity anytime, anywhere via smartphone.
Voice control: monitoring by taking with Alexa/Google home.
Easy to use: the soil moisture meter is light in size and can be carried around, plug and play, has low energy consumption, and can last for a long time. It is a good helper for your garden.
