Tuya Zigbee Temperature and Humidity Sensor Voice Control Intelligent Home Hygrometer Real-Time Monitoring Voice without Battery
Tuya ZigBee Smart Temperature And Humidity Sensor Work With Zigbee Gateway Hub Via Alexa Google Home SmartLife/Tuya App Control(NOT CR2450 battery)
Attention:
This device need connect to tuya zigbee hub. If have no the tuya zigbee hub, it will not work you, please contact us to buy a tuya zigbee hub.
How often are temperature and humidity updated?
A change in temperature of 0.3 degrees Celsius and
a change in humidity of 6 percent will upload data.
Under constant temperature, data will be uploaded every 5 minutes
