Tuya Zigbee Water Immersion Sensor Smart Life Leakage Sensor Water Level Alarm App Remote Monitoring Water Leak Detector For ZHA
  • Real-Time Water Leak Detection: The Water Immersion Sensor immediately detects leaks and sends alerts to your mobile device
  • Smart Zigbee Connectivity: Works with Zigbee 2.4GHz, ensuring stable communication within your smart home network
  • Long Battery Life: Operates on a CR2450 battery with ultra-low power consumption for long-lasting performance
  • Compact & Easy to Install: Small design with 3M adhesive for quick installation in bathrooms, laundry rooms, and basements
  • Remote Monitoring: Control and monitor your sensor from anywhere using the Tuya or Smart Life app
Shop Tuya Zigbee Water Immersion Sensor With Smart Protection Against Leaks & Overflows
Protect your home from unexpected water leaks and overflow with the Tuya Zigbee Water Immersion Sensor. This advanced Smart Water Leak Detector is designed to detect even the smallest water leaks, sending instant alerts to your smartphone via the Smart Life or Tuya app. Whether placed in kitchens, basements, or near water heaters, this Water Overflow Sensor Alarm ensures that you are always aware of potential water damage before it becomes a costly problem.
  • Real-Time Water Leak Detection: The Water Immersion Sensor immediately detects leaks and sends alerts to your mobile device.
  • Smart Zigbee Connectivity: Works with Zigbee 2.4GHz, ensuring stable communication within your smart home network.
  • Long Battery Life: Operates on a CR2450 battery with ultra-low power consumption for long-lasting performance.
  • Compact & Easy to Install: Small design with 3M adhesive for quick installation in bathrooms, laundry rooms, and basements.
  • Remote Monitoring: Control and monitor your sensor from anywhere using the Tuya or Smart Life app.
Simply place the Water Overflow Sensor Alarm near potential leak-prone areas such as sinks, water heaters, or washing machines. If water is detected, the Smart Water Leak Detector will immediately send notifications to your app, helping you take quick action.
  • Prevent Costly Water Damage: Early detection minimizes risks associated with leaks and overflows.
  • Smart Home Integration: Works seamlessly with Tuya Zigbee hubs for enhanced home automation.
  • Peace of Mind: Stay informed even when you're away with instant mobile alerts.
