Tuya Zigbee Water Leakage Sensor Flood Leak Alarm Detector Smart Home Security Protection System Smart App Remote Control Alexa
Notice:
1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T&H sensor.
2、Turn on the device and smart speaker (Amazon Alexa or Google Home speaker) , they will be connected automatically;
3、The device is also compatible with eWeLink ZigBee Gateway Hub. If TUYA Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub.
Home Security Alarm Products TUYA Zigbee Water Level Sensor Leakage Alarm Water Immersion Detector APP Remote Control Smart
TUYA Zigbee Water Level Sensor Leakage Alarm Water Immersion Detector APP Remote Control Smart Home Security Alarm products
Description:
APP: Smart Life/TUYA Smart
Working temperature: -30 ℃~70 ℃
Material: High quality ABS
Feature 1: Water leakage alarm
Feature 2: Water overflow alarm
Voice control: Alexa, Home
Connection method: zigbee
1. Real time monitoring and alarm: The device is connected through zigbee to monitor water level and leakage in real time. In case of any abnormalities, an alarm message is immediately sent to your phone to ensure that you can take timely action and minimize losses. Potential damage.
2. Easy to install: The TUYA zigbee Smart flood alarm is easy to install and does not require wiring. It only needs to be fixed near the water source to use, which is very convenient.
3. Sensitive and fast detection: The equipment adopts high sensitivity sensors, which can quickly detect changes in water level and leakage situations, and issue alarms in a timely manner to ensure your quick response.
4. Water level detection and leakage detection: The TUYA zigbee Smart flood alarm not only detects water level, but also leaks, providing you with more comprehensive home safety.
5. Long standby time: The device adopts a low-power design, which can standby for a long time without the need for frequent battery replacement, ensuring continuous operation of the device and making your use more reassuring.
6. Smart management: Through the mobile app, you can remotely monitor water levels and leakage situations anytime and anywhere, and set Smart functions such as alarm thresholds and timed on-off, making your life more Smart and convenient.
Package Included:
1*Tuya Zigbee Water Leakage Sensor
