Tuya Zigbee/Wifi Temperature Humidity Sensor Home Connected Thermometer Compatible with Smart Life Alexa Google Assistant
Pls check SKU before order goods!!!
Different SKU for different model !!!
Tips for purchase:
There are two versions: Zigbee version/WIFI version (Please choose the right item before order.) For zigbee/wifi model, user can choose the one support LCD screen or without screen
1). Zigbee version need a tuya zigbee hub to operate.
2). WIFI Version don't need a hub/gateway to operate.
3). Zigbee Gateway also could be choosed in such link
Product parameters for ZIGBEE version:
◆ APP name: Tuya Smart or Smart Life
◆ Work with Alexa and Google Home
◆ This product needs to be used with zigbee3.0 gateway
◆ Battery type: AAA1.5V*2 (Not include battery in the shipment)
◆ Quiescent current: ≤30uA
◆ Low-battery remind function
◆ Low power undervoltage: ≤2.7V
● Wireless Protocol: Zigbee 3.0
◆ Zigbee: 2.4GHz
◆ Support all Tuya smart product Linkage control
◆ Working temperature: -10℃~55℃
◆ Working humidity: 10%~90%RH
◆ Selectable temperature format ° C / ° F
◆ Temperature/Humidity high/low/release status will synchronization to app
◆ Dimension: 70*25*21mm
Product parameters for ZIGBEE LCD Screen version:
◆ Only can work when with the gateway
◆ Battery type: AAA1.5V*3(Not include battery in shipment)
◆ Low power undervoltage: ≤2.4V
◆ Zigbee: 2.4GHz
◆ Adjustable temperature/humidity report cycle/sensitivity/range
◆ Format time 12 / 24H
◆ Display date /time/temperature/humidity/battery
◆ Dimension: 56*56*23mm
Product parameters for WIFI version:
◆ Work with Alexa/Google Assistance
◆ Built-in Battery: AAA1.5V*2 (Not include battery in the shipment)
◆Wifi: 802.11b/g/n, 2.4GHz
Product parameters for WIFI LCD Screen version:
◆ Zigbee: 2.4GHz
Product package included:
1xTemperature and humidity Sensor (Not include battery)
1xSticker
1xUser manual
!!!ATTENTIONS!!!: The Zigbee Temperature and humidity sensor only will work when along with the Smart Life Zigbee Hub!!! (Users must buy Smart Life Zigbee hub first if use Zigbee Version)
Product Image:
Tuya WiFi or Zigbee model without screen:
Tuya WiFi or Zigbee model support screen:
