Tuya Zigbee3.0 Smart Window Door Gate Sensor Detector Smart Home Security Alarm System Smart Life Tuya App Remote Control
Note :The zigbee sensor must be used with zigbee gateway.
【Detect door/window status 】
When the door/window is opened or closed,the device triggered and push notification to the phone.
【Linked alarm with more sensors】
Set up the scene: away from home mode, if someone breaks in, the the device triggered and push notification to the phone., and the IP camera (not included) will shoot the video. When someone opens the door, the light turns on automatically.
【APP Remote Control 】
Whenever and wherever you are,once Door/Window Sensor detects external objects or animals, you will receive a notification by smart phone. Keep your house safe all the time.What you need to do is to keep your sensor with ZigBee hub connected.
【Wide Applications】
Apply the smart door/window sensor to different scenes,your bedroom,garage,bathroom,garden and anywhere you like,keeping your whole house away from danger with a linkage of the smart door/window sensor,together with various zigbee sensor with one zigbee hub required only. Easy to integrate into various environments.
【Easy to install】
Small size,easy to install Adhesive installation,can be flexibly placed in various doors, windows,drawers,etc,without destroying the appearance and structure of the original furniture
Input voltage:3V LR03(2Pcs AAA battery not included)
Wirless Protocol: Zigbee
Sensing Distance:10mm
Working Voltage: 3V
Standby Current: ≤40uA
Operating Temperature: -10~55℃
Operating Humidity: 0%~99%RH
APP:Smart Life APP / Tuya APP
Works With :Alexa and Google assistant
Size: Main body: 71mm*25mm*22mm
Permanent magnet: 44mm*15mm*10mm
