USA Canada Zigbee Smart Plug US Standard 10A/16A Works with Alexa Google Assistant APP Remote Control Timer Group Control
  • Works perfectly with Tuya/Smart Life ecosystem for complete home automation
  • Stable Zigbee connection ensures uninterrupted operation
  • Lower power consumption than WiFi models (only 0.2W/h standby)
Zigbee Smart Plug US Standard 10A/16A Works With Alexa Google Assistant APP Remote Control Timer Group Control for USA Canada
BSD11 US Standard Zigbee Smart Plug - 16A/10A, Works with Alexa & Google Assistant, APP Remote Control, Timer & Energy Saving
Transform Your Home with Reliable Zigbee Smart Control
The BSD11 US Standard Zigbee Smart Plug offers seamless smart home integration with superior stability and lower latency compared to WiFi plugs. Designed specifically for US, Canada, and Mexico markets, this plug converts your ordinary appliances into smart devices through the reliable Zigbee protocol.
Key Features & Benefits
Smart Home Integration
Complete Control Options
  • Remote access via smartphone from anywhere
  • Precise scheduling with timer and countdown functions
  • Group control for managing multiple devices simultaneously
  • Voice commands through Alexa, Google Assistant and more
Safety & Reliability
  • Built-in overload protection prevents damage to connected devices
  • Durable construction with V0 flame-retardant materials
  • Automatic state recovery after power failures
  • Manual override switch for local control
Technical Specifications
  • US standard plug (AC 100-240V, 50/60Hz)
  • 16A/10A selectable current rating
  • Operating temperature: -20°C to +50°C
  • Working humidity: <80% RH
  • FCC/ETL/RoHS certified
  • 100,000+ operation lifespan
Easy Setup Guide
  1. Plug the device into any standard US outlet
  2. Download and open the Tuya/Smart Life app
  3. Follow in-app instructions to add your Zigbee device
  4. Connect to your existing Zigbee hub/gateway
  5. Start controlling your appliances remotely
Zigbee Connection Notes
For optimal performance with your Zigbee smart plug:
  • Ensure your Zigbee hub is properly set up and within range (recommended within 10-15m)
  • Avoid placing the plug behind thick metal surfaces that may interfere with signal
  • The plug will automatically reconnect if temporarily disconnected
  • Regularly update your hub firmware for best compatibility
  • For large homes, consider adding Zigbee repeaters to extend network coverage
Why Choose Our Zigbee Smart Plug?
  • More reliable than WiFi with lower latency
  • Better security through encrypted Zigbee protocol
  • Reduced network congestion (doesn't use your WiFi bandwidth)
  • Longer battery life for battery-powered Zigbee devices
  • Seamless integration with existing Zigbee ecosystems
Perfect For:
  • Smart lighting control
  • Home appliance automation
  • Energy monitoring and savings
  • Vacation home security
  • Elderly care solutions
Package Includes:
1 x BSD11 Zigbee Smart Plug
1 x User Manual (English)
