USP Commercial Wide Gap Contact, 2 In. Gap, NC
$13.35
  • Wide 2-Inch Gap: Ideal for larger doors and windows, providing flexibility in installation
  • Normally Closed (NC) Configuration: Ensures a reliable and secure circuit, perfect for high-security needs
  • Commercial Grade Construction: Built to withstand the rigors of high-traffic environments
  • Easy Installation: Designed for quick and efficient setup in commercial settings
The USP Commercial Wide Gap Contact is an industry-leading security solution engineered to secure large doors and windows in commercial environments. Featuring a generous 2-inch gap, this Wide Gap Contact is perfect for installations where standard-sized contacts fall short. Designed with a Normally Closed (NC) configuration, it maintains a secure circuit when the magnet is near the contact, providing reliable protection for your property. Constructed from high-quality materials, this contact is built to withstand the demands of high-traffic areas, ensuring long-term durability and performance. Whether you're securing a warehouse, retail space, or office building, the USP Commercial Wide Gap Contact offers the robust security you need.
Features:
  • Wide 2-Inch Gap: Ideal for larger doors and windows, providing flexibility in installation.
  • Normally Closed (NC) Configuration: Ensures a reliable and secure circuit, perfect for high-security needs.
  • Commercial Grade Construction: Built to withstand the rigors of high-traffic environments.
  • Easy Installation: Designed for quick and efficient setup in commercial settings.
Benefits:
  • Enhanced Security: The Wide Gap Contact ensures that even large openings are securely monitored.
  • Reliability: The Normally Closed configuration guarantees consistent and dependable performance.
  • Durability: High-quality materials ensure the Commercial Wide Gap Contact stands up to long-term use in demanding environments.
  • Versatility: Suitable for a variety of commercial applications, from retail to industrial settings.
Usage:
  • Commercial Security: Ideal for securing doors and windows in commercial properties like offices, warehouses, and retail stores.
  • High-Traffic Areas: Perfect for locations where durability and reliability are paramount.
  • Flexible Installations: The Wide Gap Contact 2 In. design allows for installation in situations where standard contacts are insufficient.
Product Specs:
Contact Dimensions ½ x ½ x 4 inches
Rated Voltage 130VDC
Rated Current 0.5 Amps
