Vision 4 in 1 PIR Sensor
Vision 4 in 1 PIR sensor monitors movement, and send Z-Wave signal when movement is detected inside the building. With Temperature, Humidity and Light sensor built inside, it will send the signal out when temperature, humidity or light changed. When the device is secure included into Z-Wave network, above communication will be encrypted.
