Wifi Smart Switch Moudle for HomeKit 10A Smart Home Appliances Breaker Timing Voice Control Compatible with Siri Alexa Google
  • Home Assistant Switch: Fully compatible with HomeKit and Home Assistant for seamless automation
  • WiFi Smart Switch Module: Works efficiently with a 10A capacity to handle a wide range of appliances, including lights, fans, and more
  • WiFi Relay Switch: Converts ordinary switches into smart switches, adding remote control and timing capabilities
  • Voice Control: Operate your devices hands-free using Siri, Alexa, or Google Assistant
  • Compact Design: Small enough to fit behind existing switches, enabling an unobtrusive setup
The WiFi Smart Switch Module for HomeKit is the perfect solution for transforming your home into a smart, connected space. Designed for seamless integration with Siri, Alexa, and Google Home, this 10A switch is ideal for easily controlling a variety of home appliances. This WiFi Relay Switch enhances convenience and efficiency in your daily routine, featuring advanced voice control, precise timing functionality, and compatibility with HomeKit. Whether you want to automate your lights, fans, or other devices, this switch module offers reliable performance and a simple setup, making it an essential addition to your smart home system.
The WiFi Smart Switch Module for HomeKit is a compact yet powerful device designed to bring automation and intelligence to your home appliances. Featuring compatibility with leading platforms like Siri, Alexa, and Google Home, this module allows you to control your devices through voice commands or mobile apps, ensuring effortless management of your home.
  • Home Assistant Switch: Fully compatible with HomeKit and Home Assistant for seamless automation.
  • WiFi Smart Switch Module: Works efficiently with a 10A capacity to handle a wide range of appliances, including lights, fans, and more.
  • WiFi Relay Switch: Converts ordinary switches into smart switches, adding remote control and timing capabilities.
  • Voice Control: Operate your devices hands-free using Siri, Alexa, or Google Assistant.
  • Compact Design: Small enough to fit behind existing switches, enabling an unobtrusive setup.
  • Scheduling & Timer Functionality: Automate routines with scheduling and countdown timers for energy efficiency.
  • App Control: Use your smartphone to control appliances anytime, anywhere remotely.
  • Enhance convenience by automating daily tasks.
  • Improve energy efficiency with precise scheduling.
  • Compatible with smart home ecosystems, including Home Assistant Switch and HomeKit.
  • Easy installation and seamless integration with existing wiring.
Perfect for homes, offices, or any space requiring smart automation. The module works with WiFi and does not require a separate hub, making it easy to install and operate. Transform traditional devices into smart ones and control them remotely using the app or voice commands.
Upgrade your home with the reliable WiFi Smart Switch Module and enjoy the power of a truly connected environment!
