Works with Homekit Water Leak Sensor Zigbee 3.0 Wireless Flood Detector for Alarm System and Smart Home Automation Apple Homekit
Works with HomeKit Water Leak Sensor Zigbee 3.0 Wireless Flood Detector for Alarm System and Smart Home Automation Apple HomeKit Tuya SmartLife
Notice!Notice!Notice!
This device does not have a device ID QR code.It does not work direct with Apple TV and HomeKit.
This device cannot be directly linked to Apple Home APP, this HomeKit device needs to work whih HomeKit hub/gateway.
Product Parameters:
● Detect water leakage and push notification to mobile phone
● App remote control
● Free IOS & android APP
● Power supply: AA*2PCS(Not Included)
● Working current: 58mA
● Standby current: 2.5uA
●Working temp.: 0°C ~ 50°C
●Working hum.: 20% ~ 85%
●Working times: 5000
●Wireless frequency: 2.4GHz
●Wireless protocol:HomeKit, Zigbee 3.0, IEEE 802.15.4
●Network range: 55M
●Size: 82mm*42mm*16mm
Package List:
1* HomeKit Water Sensor
1* User Manual(English)
Notice:
1.This is a dual-purpose Water Leak Sensor, which can be used as a ZigBee 3.0 device to connect with TUYA APP, or as a HomeKit Water Sensor to connect with Apple Home APP.
2.This device cannot be directly linked to Apple Home APP, this HomeKit device needs to work whih HomeKit hub/gateway.
3.Since there is no option to directly remove the sub-device in the HomeKit gateway in the Apple Home APP, it is necessary to delete the sub-device from the TUYA APP, and the Apple Home APP will remove it synchronously. For details, please refer to the demo video. thanks.
4.Note that this device cannot be directly connected to phone.
If you are using TUYA / Smart Life APP, you need to use a ZigBee gateway to access this device.
If you are using the Apple Home APP, you need to use a HomeKit ZigBee gateway to access this device.
