X10 Companion Wall Switch for WS4777, White
$8.99
Three-Way Compatibility: The X10 Companion Switch is specifically engineered to function alongside the WS4777 Master Switch, facilitating control over a single incande..
Local Control: Equipped with a push-button on both the master and companion switches, users can effortlessly turn lights on or off and adjust brightness levels directl..
Expandable Configuration: For more complex lighting setups, additional companion switches can be integrated to create four-way or even more extensive control systems, ..
The X10 Companion Wall Switch is an essential accessory designed to work seamlessly with the WS4777 3-Way Wall Dimmer Switch Kit, enabling efficient control of your home's lighting system. This companion switch allows for convenient three-way operation, making it possible to control a single light source from multiple locations within your home. Whether you need to upgrade your lighting setup or improve accessibility, the X10 Wall Switch ensures smooth and reliable operation.
- Three-Way Compatibility: The X10 Companion Switch is specifically engineered to function alongside the WS4777 Master Switch, facilitating control over a single incandescent light from two distinct locations.
- Local Control: Equipped with a push-button on both the master and companion switches, users can effortlessly turn lights on or off and adjust brightness levels directly from either switch.
- Expandable Configuration: For more complex lighting setups, additional companion switches can be integrated to create four-way or even more extensive control systems, providing flexibility for various home layouts.
Ideal for hallways, staircases, or large rooms with multiple entry points, the X10 Companion Wall Switch enhances convenience by allowing light control from various locations. Installation is straightforward, requiring the replacement of existing switches with the WS4777 Master Switch and the corresponding X10 Companion Switch. This setup ensures synchronized control over your lighting fixtures.
- Enhanced Convenience: Operate your lighting from multiple points, reducing the need to traverse rooms to access a single switch.
- Customizable Lighting: The dimming feature enables you to set the perfect ambiance for any occasion, whether it's a cozy evening or a lively gathering.
- Cost-Effective Solution: Achieve advanced lighting control without the need for expensive or complex wiring systems.
Technical Specifications:
- Power Rating: 120VAC, 60Hz, Max 1/10 Amp
- Load Compatibility: Designed for incandescent bulbs ranging from 40W to 500W
- Color: White
Please note that the X10 Wall Switch is intended for use with incandescent lighting only and is not compatible with appliances, motors, low-voltage lights, or fluorescent lamps. For optimal performance, ensure that all components, including the X10 Companion Switch, are correctly installed and configured according to the provided instructions.
