X10 Duplex Wall Receptacle (Both Outlets Controlled), White
$38.95
Dual Controlled Outlets: Both outlets respond to X10 ON/OFF commands, enabling synchronized control of two connected devices
High Load Capacity: Supports heavy-duty appliances with a maximum load of 20 amps at 120V, suitable for air conditioners, washers, dryers, and more
Feed-Through Wire: Includes a blue feed-through wire that can control additional non-X10 receptacles or external loads, expanding your automation capabilities
Local Control Feature: Senses when a connected device is manually turned on, automatically responding by powering the device, ensuring consistent operation
The X10 Duplex Wall Receptacle is a robust solution for remotely managing your home's electrical devices. Unlike standard outlets, this Receptacle Duplex allows both outlets to be controlled simultaneously via X10 commands, providing seamless integration into your smart home system.
- Dual Controlled Outlets: Both outlets respond to X10 ON/OFF commands, enabling synchronized control of two connected devices.
- High Load Capacity: Supports heavy-duty appliances with a maximum load of 20 amps at 120V, suitable for air conditioners, washers, dryers, and more.
- Feed-Through Wire: Includes a blue feed-through wire that can control additional non-X10 receptacles or external loads, expanding your automation capabilities.
- Local Control Feature: Senses when a connected device is manually turned on, automatically responding by powering the device, ensuring consistent operation.
Ideal for automating household appliances and lighting, the X10 Duplex Wall Receptacle integrates effortlessly with your existing X10 home automation system. By utilizing the X10 powerline interface, it transmits control signals over your home's electrical wiring, eliminating the need for additional wiring or complex installations.
- Enhanced Convenience: Remotely control multiple devices from a central X10 controller, streamlining your daily routines.
- Energy Efficiency: Easily turn off appliances when not in use, reducing energy consumption and lowering utility bills.
- Safety: Automate lighting and appliances to create the appearance of an occupied home, enhancing security during absences.
Specifications
- Operating Voltage: 110-120 volts AC
- Maximum Current: 20 amps total
- Minimum Load: 40 watts
- Dimensions: 2.75" (H) x 1.75" (W) x 1.5" (D); 4.125" height including mounting tabs
Upgrade your home automation setup with the X10 Duplex Wall Receptacle, and experience the convenience and efficiency of centralized control over your electrical devices.
