X10 PRO 2-Button Keypad (2-Address), Ivory
$11.95
The X10 PRO 2-Button Keypad (2-Address) is a sleek and stylish device that allows you to control your home automation system with ease. Featuring an ivory finish, this keypad is designed to blend seamlessly into any décor. With its two-button design, you can easily turn on and off lights, appliances, and other devices in your home. The keypad is compatible with X10 PRO modules, and can be programmed to control up to two separate addresses. Installation is quick and easy, and the keypad can be mounted on any flat surface. With the X10 PRO 2-Button Keypad, you'll enjoy convenient and effortless control over your home automation system.
