The X10 PRO 2-Button Keypad (2-Address) in white is a versatile and easy-to-use home automation device. With two buttons and two addresses, you can control multiple X10-compatible devices with a simple press of a button. The sleek white design blends seamlessly with any home decor, and the compact size allows for easy placement in any room. The keypad is easy to install and set up, and works with any X10-compatible controller or interface. Whether you want to turn off the lights from bed, or control your home theater system from across the room, the X10 PRO 2-Button Keypad makes home automation simple and convenient.
