X10 PRO 4-Button Keypad (3 Address & 1 Dimmer), White
$11.95
The X10 PRO 4-Button Keypad is a versatile and convenient device for controlling your home's lighting and other X10 compatible devices. With four buttons, including three address buttons and one dimmer button, this keypad allows you to quickly and easily turn lights on and off, adjust their brightness, and control other devices with just a few simple presses. The keypad is designed in a sleek and stylish white finish, making it a perfect addition to any home decor. Its compact size allows for easy installation and it can be mounted on any surface for quick access. With reliable X10 technology, this keypad is sure to provide you with years of hassle-free use. Upgrade your home's lighting system with the X10 PRO 4-Button Keypad.
