X10 PRO 4-Button Keypad (4 Address), White
$11.95
Four ON/OFF Buttons: Control up to four devices or groups with dedicated buttons, providing straightforward management of your home lighting and appliances
Elegant Design: The X10 PRO white keypad switch offers a clean, modern appearance that integrates seamlessly with any home décor
Easy Installation: Mounts into a standard single-gang wall box and connects to the XPT base unit, simplifying the setup process
The X10 PRO 4-Button Keypad (4 Address) is a versatile wall-mounted controller designed to enhance your home automation system. When paired with the XPT Wall Transmitter Base, this X10 PRO white multi-button switch enables seamless ON/OFF control of four sequential X10 addresses, allowing you to manage multiple devices from a single, centralized location.
- Four ON/OFF Buttons: Control up to four devices or groups with dedicated buttons, providing straightforward management of your home lighting and appliances.
- Elegant Design: The X10 PRO white keypad switch offers a clean, modern appearance that integrates seamlessly with any home décor.
- Easy Installation: Mounts into a standard single-gang wall box and connects to the XPT base unit, simplifying the setup process.
Ideal for both residential and commercial settings, this keypad allows users to control various devices such as lights, fans, and other appliances. By installing multiple keypads throughout your property, you can establish a comprehensive control system without the need for additional wiring.
- Enhanced Convenience: Manage multiple devices from a single location, reducing the need for multiple switches and streamlining your control system.
- Flexible Control: The four-address capability allows for customized setups, enabling you to control individual devices or groups as needed.
- Aesthetic Appeal: The sleek design of the X10 PRO white multi-button switch complements any interior, adding both functionality and style to your space.
