Experience the future of lighting control with the innovative X10 PRO Inductive Fixture Module. This hidden gem goes beyond simple on/off functionality, transforming your existing fixtures into smart, automated wonders.
Effortless Control from Within:
Unlike bulky external modules, the X10 PRO Inductive Fixture Module installs discreetly inside your light fixture. It utilizes inductive sensor technology, eliminating the need for direct line-of-sight with a remote control. This means hidden fixtures in recessed cans or behind furniture can finally be conveniently controlled.
Seamless X10 Integration:
The X10 PRO Inductive Fixture Module integrates seamlessly with your existing X10 home automation system (X10 devices sold separately). This allows you to control your lights using familiar remotes, wall controllers, or even smartphone apps. Schedule lights to turn on at sunrise, create lighting scenes for different moods, or even group multiple fixtures together for effortless control of your entire home environment.
Works with Most Fixture Types:
The X10 PRO Inductive Fixture Module boasts impressive compatibility. It works with a wide range of inductive lighting fixtures, including incandescent, fluorescent, and compact fluorescent bulbs. This makes it a versatile solution for upgrading your existing lighting setup without needing to replace your bulbs.
Here are some of the benefits of the X10 PRO Inductive Fixture Module:
Hidden installation for a clean, modern look
Inductive sensor technology for control from anywhere in the room
Works with most inductive lighting fixtures
Seamless integration with your X10 home automation system
Control lights remotely, create scenes, and set schedules
Take control of your home's lighting and experience the convenience of automation with the X10 PRO Inductive Fixture Module. Order yours today and discover a smarter way to illuminate your life.
