Introducing the Yale Assure Lock 2 Keypad with Bluetooth in Oil-Rubbed Bronze—a sophisticated and secure solution for modern access control. This Yale Deadbolt Lock combines advanced technology with elegant design, offering keyless convenience and enhanced security for your home.
Keyless Entry: Eliminate the need for traditional keys with this Keyless Lock Door system. Access your home effortlessly using a personalized code on the backlit keypad, ensuring visibility in any lighting condition.
Bluetooth Connectivity: Seamlessly connect the lock to your smartphone via Bluetooth. Utilize the Yale Access App to lock, unlock, and manage access remotely, providing control and peace of mind from anywhere.
Customizable Access: Create and manage up to 25 unique PIN codes for family members, friends, or guests. Easily assign and revoke codes as needed, enhancing security and flexibility.
Auto-Lock Feature: Program the lock to automatically secure the door after a set period, ensuring your home remains protected even if you forget to lock up.
Sleek Design: The oil-rubbed bronze finish adds a touch of elegance to any door, while the slim profile complements various architectural styles.
Enhanced Security: The absence of a keyway in this Key-Free Touchscreen Lock eliminates the risk of lock picking or bumping, providing a higher level of security for your home.
Convenience: Experience the ease of keyless entry and remote access management, reducing the hassle of carrying physical keys.
Integration: Compatible with various smart home systems, allowing for integration into your existing home automation setup.
Ideal for residential properties, the Yale Assure Lock 2 is perfect for homeowners seeking a reliable and stylish keyless entry solution. Whether replacing an existing deadbolt or upgrading to a smarter system, this lock offers straightforward installation and user-friendly operation.
Additional Information
The Yale Assure Lock 2 is designed with user convenience in mind, featuring voice guidance for setup and operation. The lock is powered by four AA batteries, ensuring long-lasting performance without the need for hardwiring. In case of low battery, the lock provides audible alerts, and a 9V battery terminal allows for emergency power to gain entry.
