Yale Z-Wave Plus Assure Push Button Keypad Lever Lock, Satin Nickel
Regular price $229.99
Regular price $229.99 Sale price
Shop Yale Z-Wave Door Lock with Handle Push Button In Satin Nickel
The Yale Z-Wave Plus Assure Push Button Keypad Lever Lock in Satin Nickel is a sophisticated and secure solution for modern homes. This Z-Wave smart door lock offers keyless entry through a backlit push-button keypad, eliminating the need for traditional keys and enhancing the convenience of accessing your home.
  • Keyless Entry: Easily lock and unlock your door using the backlit push-button keypad, providing a seamless entry experience without fumbling for keys.
  • Z-Wave Plus Technology: Integrates smoothly with various Z-Wave smart home systems, allowing remote control and monitoring of your lock via compatible apps.
  • Customizable User Codes: Create and manage unique entry codes for family members and guests, enhancing security and control over who accesses your home.
  • Auto-Lock Function: Enable the auto-lock feature to ensure your door automatically locks behind you, providing peace of mind that your home is secure.
  • Satin Nickel Finish: The sleek satin nickel finish complements various home décors, adding a touch of elegance to your entryway.
Ideal for side entry doors, garage entry, basement doors, and home offices, this Z-Wave door lock with handle replaces your existing lever or knob, fitting doors with a single hole prep. Installation is straightforward, requiring only a screwdriver. By integrating this Z-Wave smart home lock into your automation system, you can remotely manage access, receive notifications, and ensure your home is always secure.
Backed by Yale's reputation for quality since 1840, the Assure Lever Lock combines advanced technology with trusted security, making it a valuable addition to any smart home
Finish Satin Nickel
Backset 2-3/8 Inch or 2-3/4 Inch Adjustable, Square Corner
Strike 1-1/8" x 2-3/4" Round Corner Strike
Design Keypad
Keyway Kwikset KW1
Function 216-Keypad Lever Lock
Door Thickness 1-3/8" to 1-3/4"
Bore Size 2.1250
Cylinder Type Conventional
Finish Description Satin Nickel
ADA Compliant No
Included Components Touchscreen Keyed Entry Lock; Keys; Mounting Hardware
Keying Type Keyed Different
Keyblank Grouping YALR-KW1-5-1
Door Cross Bore 2.125 Inch
Keying Charges Residential-Conventional
Product Material Metal
Product Type Touchscreen Lock
Grade ANSI/BHMA Grade 2
Box Length 12.6300
Box Width 5.5000
Box Height 3.6300
Warranty Lifetime Limited Warranty Finish And Mechanical Mechanical hardware
Color Code 619/US15
Product Height 12.63 Inch
Product Width 5.5 Inch
Corner Type Round Corner
Finish Family Satin Nickel
Strike Size 1-1/8" x 2-3/4"
Standards ANSI/BHMA
Function Family Keypad Lock
Features Enable Auto Relock
Bolt Backset 2-3/8" or 2-3/4"
Manufacturer Parent Assa Abloy
Door Edge Bore 1 Inch
Box Dimensions (L x W x H) 12.625x5.5x3.625
Sub-Series YRL216-ZW2-619
