The Yale Z-Wave Plus Push-Button Deadbolt Assure Lock Gen5 offers state-of-the-art security for your home. With its oil-rubbed bronze finish and robust build, it combines modern aesthetics with advanced features. Designed to work seamlessly with Z-Wave home automation systems, this lock allows you to remotely control and monitor your door, whether you’re at home or away.
Features and Benefits
Enhanced Security: The Push-Button Deadbolt design ensures reliable protection, featuring tamper alarms and a sturdy ANSI/BHMA Grade 2 certification.
Smart Integration: Connect with over 50 Z-Wave systems, such as SmartThings and Alarm.com, to lock/unlock, create PIN codes, and receive alerts from anywhere.
User-Friendly Operation: The backlit keypad on the Yale Button Lock provides visibility in low light and durability with wear-resistant buttons.
Customizable Access: Create up to 250 unique PIN codes for guests, family, or service providers when connected to a Z-Wave hub.
Convenience of Keyless Entry: Say goodbye to lost keys with electronic keyless access or use the included physical key for added peace of mind.
Applications and Usage
Ideal for homeowners seeking an easy-to-install, smart security solution, the Yale Z-Wave Plus is compatible with standard door sizes (1-3/4" to 2-1/4" thick). Installation is quick with just a screwdriver, and its weather-resistant build ensures performance in all climates. This Yale Security Electronic Push-Button Deadbolt is perfect for securing residential properties, rental units, or offices.
Key Benefits
Remote Monitoring: Keep tabs on access history and door status via Z-Wave-connected devices.
Enhanced Durability: Built to withstand tough environmental conditions.
Flexibility: Compatible with leading smart home ecosystems like Alexa and Google Assistant.
Equip your home with the Yale Z-Wave Plus Push-Button Deadbolt, combining style, functionality, and top-tier security. Unlock the future of convenience and safety today
